Hello Forum! Anyone having issues with pairing time outs, please try this solution listed below. This was shared by an awesome community member and I thought it deserved its own thread.
From the community member:
“I fixed it by doing the following.
My wireless router was actively blocking the cameras IP address.
I found this by watching which IP address was being assigned to the camera after it connected to the wifi. then went into my security settings for the router and saw it had a red X on it. I then added the IP address to the “Good” list and went through the setup again. worked right away.
If you are getting it to connect to the wifi then its highly likely that the router is blocking the IP address for the camera.
hope this helps”
Thanks for the suggestion! Please give this a try if you’re having pairing time out issues.
