Yi 1080p home IA no wifi dev
Hello, I have a 9fusy model of yi 1080 home since August 2020. A month ago I noticed that the yellow light was always on.
I unplug it and perform a reset. since then, I can’t use it. It remains in a loop asking for the wifi and once it recognizes the qr-code it restarts.
Inside the sd I have found a log file, where it says that it restarts because there is no wifi device.
the wifi user and password is correct.
I have tried to load multiple versions of the firmware, but in all the same problem, no wifi dev.
I just opened a ticket.
Has anyone had the same problem?
Hello. Could you read through the following thread and try the items listed in it.
If you still continue to have issues check this support article.
@dbizarro i have the same problem. they sent me a new camera but i am still trying to understand if it is possible tu use it.
did you solve?
