Hi Fam, im here again.
I noticed since the last update, I can see only 3 days with my 32GB SD Card???
Can someone clarify this, if this is correct?
Before I could see 4 to 5 day back.
Thanks Fam
Thanks Fam
Hi. Yi is working on this as part of the improvements to the application.
Thnx York for the support.
Hope they resolve this soon. Pls keep us inform.
Kind regards,
Martis
Hello - I also realized that with the SD card, I cannot record video clips as I’m viewing past clips.
Is this supposed to be that way?
Hello. No this is not how it should work. It could be part of issues experienced by Yi since the new application was issued
Ok, thanks. Does this mean there’s a potential update that will follow that will allow for recording of video clips off of the SD card?
If the app is restored as it was you could use a video function with the app to record previous SD card footage.
Please go here to learn about SD Card playback in the new app.
I was wondering does it really matter if I put an 32Gb or 64Gb or 128Gb?! Considering that the app give 2 days to playback form the SD card
I often think it’s best to go on the specs set out by the manufacturer. But I know sole have put in larger capacity cards and they work.
Even with the new app you should be able to see more than two days on your SD card.
Hi York,
Ok! But im very sure that we could see more then 2 days with 32GB. After the update is only 2
But I wait and see what the updates brings
I get around 4/5 days with 64gb cards recording 24*7 HD quality.
You can use the scroll bar to go beyond 2 days. We are working to fix the drop down menu in an upcoming release. If you turn motion detection off, you can record a decent amount. See Yorkshires post above
Hey @jack01 Thanks for coming to the forum. Can you confirm what version of the app you are using and what are you using iOS or Android?
Hi, Im having a playback issue where I cannot play from SD card. If I try to scroll back on the current day (today), i get an error showing “No Video recorded to SD card on Today”. There is recorded video and even motion trigger records that I can see.
Scrolling back to previous day I could see video. If I let video running from close to midnight to next day (today) video continue playing, so there’s video, but I cannot scrollback and select time I need.
I’ seeing same issue on
YI home 5.0.2
Kami 3.0.2
I too am only seeing 2 (sometimes depending on the time of day i do see 3) days worth, using 32gb 64gb or 128gb
Tried formatting cards to no avail still only 2 or 3 days show in drop down, swiping timeline makes no difference
using kami home app
3.11_20210920
yi app
5.1.1_20210929
Android 10
Can you guys try updating your firmware, reformatting your SD cards, then remove your camera from the app, reset and pair the camera again
Let me know how these troubleshooting suggestions go
Tried upgrading FW but I am using the latest, formatting did not solved the issue.
Found the App Upgrade from 8h ago, upgraded the app and the problem is gone now. Working!
