Hi there,
I have a Dome smart camera, but it doesn’t seem to pair with the app. It starts up, and after 20 seconds starts to make 2-beeps, which repeats every 5 seconds or so. But when I try to pair it, and point the code on my smartphone at the camera, nothing happens (even if I put it close or far). It just keeps beeping, and the light coming from the body of the camera is red. I have tried to upgrade the firmware, using the filename ‘home’, ‘home.bin’, ‘home_v201’, etc. Nothing seems to work. I have also held down the reset button for a few seconds, and then also for up to 1 minutes, but nothing works.
In the log, I see it is ID A0000000R6IRJ7181011.
Can you help me?
Here is the full log on startup:
10-24 10:24:08.638 cloud.c:4938|sys_init() open share mem ok
10-24 10:24:09.002 dispatch.c:884|get_productinfo() product info partition is not empty, read it!
10-24 10:24:09.242 dispatch.c:1213|get_config() got sn(Y7501d1311iRj4fHoU7EFT7MwGMNQ71n)
10-24 10:24:09.242 dispatch.c:1214|get_config() got pwd()
10-24 10:24:09.242 dispatch.c:1215|get_config() got ssid()
10-24 10:24:09.242 dispatch.c:1216|get_config() got tnp_init_string()
10-24 10:24:09.242 dispatch.c:1224|get_config() reset because no wifi config
10-24 10:24:09.242 dispatch.c:413|send_saveconfig_msg() send_saveconfig_msg msg snd success
10-24 10:24:09.243 dispatch.c:1271|get_config() get_config save conf
10-24 10:24:09.243 dispatch.c:548|get_hw_version() did = A0000000R6IRJ7181011 product id = 1 ========
10-24 10:24:09.243 dispatch.c:5235|main() hw_type(2)
10-24 10:24:09.243 p2p_tnp.c:6494|main() fshare_open ok
10-24 10:24:09.485 p2p_tnp.c:2050|p2p_set_tnp_init_status() p2p_set_tnp_init_status 1 send_msg ok!
10-24 10:24:09.869 watch_process.c:116|get_watch_info() check_interval=10
10-24 10:24:09.924 watch_process.c:134|get_watch_info() process=dispatch;cmd=cd /home/app;./dispatch &;
10-24 10:24:09.924 watch_process.c:134|get_watch_info() process=cloud;cmd=cd /home/app;./cloud &;
10-24 10:24:09.924 watch_process.c:134|get_watch_info() process=rmm;cmd=reboot;
10-24 10:24:09.924 watch_process.c:134|get_watch_info() process=p2p_tnp;cmd=cd /home/app;./p2p_tnp &;
10-24 10:24:09.924 watch_process.c:134|get_watch_info() process=mp4record;cmd=cd /home/app;./mp4record &;
10-24 10:24:09.925 watch_process.c:134|get_watch_info() process=arp_test;cmd=cd /home/app;./arp_test &;
10-24 10:24:09.925 watch_process.c:134|get_watch_info() process=oss;cmd=cd /home/app;./oss &;
10-24 10:24:10.638 dispatch.c:654|choose_server() in choose_server, region_id = 1, api_server = https://plt-api.xiaoyi.com, sname = neutral-r10, dlproto = micn
10-24 10:24:10.639 dispatch.c:5322|main() ioctl(536899612) error(1),Operation not permitted
10-24 10:24:10.640 dispatch.c:5368|main() init ok, cost time(2103 ms)
10-24 10:24:10.641 dispatch.c:3413|do_mq_process() dispatch got (0x7f)
10-24 10:24:10.641 dispatch.c:5047|do_mq_process() Process (0x7f) end
10-24 10:24:10.655 dispatch.c:1832|ptz_stop() PTZ stop OK
10-24 10:24:10.659 dispatch.c:3204|p_worker() ioctl(536899596) error(1),Operation not permitted
10-24 10:24:10.659 dispatch.c:1052|save_config() got pwd()()
10-24 10:24:10.659 dispatch.c:1053|save_config() got ssid()()
10-24 10:24:10.660 dispatch.c:1054|save_config() config save finish 1
10-24 10:24:10.874 dispatch.c:3231|p_worker() save_config
01-19 06:41:36.100 dispatch.c:3319|p_worker() DISPATCH_SET_DEFAULT_TIME 1453185696
01-19 06:41:37.458 rmm.c:1308|msg_proc() pid[589]
01-19 06:41:37.551 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:41:37.552 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:41:37.552 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:41:37.552 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:41:37.552 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:41:37.854 rmm.c:1609|zbar_proc() Got raw video size(320,192)
01-19 06:41:43.619 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:41:43.619 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:41:43.619 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:41:43.621 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:41:43.624 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:41:43.920 dispatch.c:1832|ptz_stop() PTZ stop OK
01-19 06:41:44.797 watch_process.c:171|check_watch_info() arp_test crashed!
01-19 06:41:46.861 dispatch.c:1832|ptz_stop() PTZ stop OK
01-19 06:41:46.865 dispatch.c:1832|ptz_stop() PTZ stop OK
01-19 06:41:49.835 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:41:49.835 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:41:49.835 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:41:49.837 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:41:49.840 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:41:51.014 dispatch.c:1832|ptz_stop() PTZ stop OK
01-19 06:41:52.537 dispatch.c:1832|ptz_stop() PTZ stop OK
01-19 06:41:55.982 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:41:55.985 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:41:55.985 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:41:55.987 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:41:55.988 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:42:02.137 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:42:02.137 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:42:02.137 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:42:02.139 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:42:02.141 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:42:08.296 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:42:08.296 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:42:08.296 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:42:08.297 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
01-19 06:42:08.299 rmm.c:1151|send_wait_msg() msg snd success
01-19 06:42:14.453 dispatch.c:3413|do_mq_process() dispatch got (0x1002)
01-19 06:42:14.453 dispatch.c:5043|do_mq_process() invalid msg 0x1002
01-19 06:42:14.453 dispatch.c:5047|do_mq_process() Process (0x1002) end
01-19 06:42:14.454 rmm.c:1348|msg_proc() got RMM_SPEAK_WAIT
