Hello there
My yihome 1080p model device with serial number 9FUSY31RK2 keeps giving an error. Even though I enter the wifi password correctly, I get the wrong error.It was working before. This happened after the firmware update.
I think the firmware is faulty.I tried everything this community said. My wifi password is correct and 2.4 ghz .My phone is android version 11.i can’t solve the problem.There are log files attached.
[./dispatch][1/1/0:0:9:896]: dispatch.c(main-5290) open_ptz fail[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1264) got sn(RZuiYnzWal7Y9u5Gj0K4sQ4cEeqtsBsi)[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1265) got pwd()[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1266) got ssid()[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1267) got tnp_init_string()[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1275) reset because no wifi config[./dispatch][1/1/0:0:10:20]: dispatch.c(send_saveconfig_msg-425) send_saveconfig_msg msg snd success[./dispatch][1/1/0:0:10:20]: dispatch.c(get_config-1322) get_config save conf
[./dispatch][1/1/0:0:10:20]: dispatch.c(choose_server-660) in choose_server, region_id = 17, api_server = https://api.us.xiaoyi.com, log_server = http://log.us.xiaoyi.com, sname = familymonitor-y20ga, dlproto = mius
[./dispatch][1/1/0:0:10:20]: dispatch.c(choose_server-660) in choose_server, region_id = 8, api_server = https://api.xiaoyi.com.tw, log_server = http://log.xiaoyi.com.tw, sname = familymonitor-y20ga, dlproto = aws
[./dispatch][1/1/0:0:10:32]: dispatch.c(main-5371) init ok, cost time(2553 ms)[./dispatch][1/1/0:0:10:35]: dispatch.c(save_config-1068) got pwd()()[./dispatch][1/1/0:0:10:36]: dispatch.c(save_config-1069) got ssid()()[./dispatch][1/1/0:0:10:36]: dispatch.c(save_config-1070) config save finish 1[./dispatch][1/1/0:0:10:286]: dispatch.c(p_worker-3229) save_config[./dispatch][1/19/6:41:36:97]: dispatch.c(p_worker-3320) DISPATCH_SET_DEFAULT_TIME 1453185696[./rmm][1/19/6:41:36:258]: rmm.c(main-1715) --insmod /home/qigan/ko/sensor_power.ko dvdd0_vol=“1800000” mclk0=“27000000” success–[./rmm][1/19/6:41:36:366]: rmm.c(main-1734) --insmod /home/qigan/ko/sp2305_mipi.ko success–[./rmm][1/19/6:41:36:437]: rmm.c(main-1747) --insmod /home/qigan/ko/vin_v4l2.ko ccm0=“sp2305_mipi” i2c0_addr=“0x78” success–[./rmm][1/19/6:41:36:539]: rmm.c(msg_proc-972) pid[570][./mp4record][1/19/6:41:37:308]: mp4record.c(main-1207) init_finish(1), start_with_reset(1)[./p2p_tnp][1/19/6:41:37:361]: p2p_tnp.c(main-6645) fshare_open ok[./p2p_tnp][1/19/6:41:37:389]: p2p_tnp.c(p2p_set_tnp_init_status-2110) p2p_set_tnp_init_status 1 send_msg ok!
[./cloud][1/19/6:41:37:389]: cloud.c(sys_init-5402) open share mem ok
[./rmm][1/19/6:41:37:544]: rmm.c(init_font-334) font:/home/base/iso8859-1-24x48.bin
[./rmm][1/19/6:41:37:546]: rmm.c(init_font-346) filesize=36864
[./rmm][1/19/6:41:37:550]: rmm.c(init_font-366) init font /home/base/iso8859-1-24x48.bin ptr size(4)[./rmm][1/19/6:41:37:550]: rmm.c(init_font-334) font:/home/base/iso8859-1-8x16.bin
[./rmm][1/19/6:41:37:551]: rmm.c(init_font-346) filesize=4096
[./rmm][1/19/6:41:37:551]: rmm.c(init_font-366) init font /home/base/iso8859-1-8x16.bin ptr size(4)[./rmm][1/19/6:41:37:877]: v429_mpp.c(rmm_set_mirror_filp-3314) set ISP mirror and filp to 0
[./rmm][1/19/6:41:37:920]: rmm.c(send_wait_msg-452) msg snd success[./dispatch][1/19/6:41:37:921]: dispatch.c(do_mq_process-5068) invalid msg 0x1002
[./rmm][1/19/6:41:37:925]: rmm.c(msg_proc-1012) got RMM_SPEAK_WAIT[./watch_process][1/19/6:41:38:352]: watch_process.c(get_watch_info-116) check_interval=10
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=dispatch;cmd=cd /home/app;./dispatch &;
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=cloud;cmd=cd /home/app;./cloud &;
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=rmm;cmd=reboot;
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=p2p_tnp;cmd=cd /home/app;./p2p_tnp &;
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=mp4record;cmd=cd /home/app;./mp4record &;
[./watch_process][1/19/6:41:38:407]: watch_process.c(get_watch_info-134) process=oss;cmd=cd /home/app;./oss &;
[./rmm][1/19/6:41:56:856]: rmm.c(trans_info-112) trans_json info=b=SGj9DjbENOxxYN4k&s=QkFGSE9NRQ==&p=aFg5NSQFHVwKFCRJQUwH;key=&p=
[./rmm][1/19/6:41:56:856]: rmm.c(trans_info-184) trans_json result=aFg5NSQFHVwKFCRJQUwH
[./rmm][1/19/6:41:56:856]: rmm.c(trans_info-112) trans_json info=b=SGj9DjbENOxxYN4k&s=QkFGSE9NRQ==&p=aFg5NSQFHVwKFCRJQUwH;key=&s=
[./rmm][1/19/6:41:56:857]: rmm.c(trans_info-184) trans_json result=QkFGSE9NRQ==
[./rmm][1/19/6:41:56:857]: rmm.c(trans_info-112) trans_json info=b=SGj9DjbENOxxYN4k&s=QkFGSE9NRQ==&p=aFg5NSQFHVwKFCRJQUwH;key=b=
[./rmm][1/19/6:41:56:857]: rmm.c(trans_info-184) trans_json result=SGj9DjbENOxxYN4k
[./dispatch][1/19/6:41:56:857]: dispatch.c(do_mq_process-5068) invalid msg 0x1005
[./rmm][1/19/6:41:56:858]: rmm.c(send_scanok_msg-479) msg snd success[./dispatch][1/19/6:41:56:859]: dispatch.c(choose_server-660) in choose_server, region_id = 8, api_server = https://api.xiaoyi.com.tw, log_server = http://log.xiaoyi.com.tw, sname = familymonitor-y20ga, dlproto = aws
[./rmm][1/19/6:41:56:864]: rmm.c(msg_proc-1097) got RMM_SPEAK_SCAN_OK[./rmm][1/19/6:41:56:866]: rmm.c(send_wifi_conf_msg-509) msg snd success[./dispatch][1/19/6:41:56:888]: dispatch.c(do_mq_process-3446) got pwd(PasswordBAF!.92)[./dispatch][1/19/6:41:56:888]: dispatch.c(send_connectting_msg-137) msg snd success[./dispatch][1/19/6:41:56:888]: dispatch.c(do_mq_process-5068) invalid msg 0x1004
[./rmm][1/19/6:41:56:890]: rmm.c(msg_proc-1032) got RMM_SPEAK_CONNECTTING[./dispatch][1/19/6:41:57:319]: dispatch.c(do_monitor_wifi-1738) wifi disconnected, now reconnect wifi
[./watch_process][1/19/6:41:58:353]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./dispatch][1/19/6:42:1:829]: dispatch.c(do_monitor_wifi-1748) wpa connected , now dhcp
[./dispatch][1/19/6:42:1:834]: dispatch.c(do_monitor_wifi-1750) wpa connected , now dhcp finish
[./watch_process][1/19/6:42:8:353]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:8:353]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./watch_process][1/19/6:42:18:353]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:18:354]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./watch_process][1/19/6:42:28:354]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:28:354]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./dispatch][1/19/6:42:36:407]: dispatch.c(p_worker-3350) rcd may crashed
[./watch_process][1/19/6:42:38:354]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:38:354]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./watch_process][1/19/6:42:48:355]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:48:355]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./watch_process][1/19/6:42:58:355]: watch_process.c(check_watch_info-171) cloud crashed![./watch_process][1/19/6:42:58:355]: watch_process.c(check_watch_info-171) p2p_tnp crashed![./dispatch][1/19/6:42:59:781]: dispatch.c(do_monitor_wifi-1701) timeout reset wifi
[./dispatch][1/19/6:42:59:781]: dispatch.c(do_monitor_wifi-1704) wifi connect timeout
