Have you solved the problem?
Hey @tomaso.dincalevis this has not been a widespread issue. Can you tell me a little bit more about what is going on with your pairing issues?
Is your wifi set to 2.4ghz or 5g? What about your phone?
First time pair or are you trying to repair the device? If repairing, did you delete the camera from your account before going through the pairing process again.
Are you using an SD card or cloud sub?
How far away from the camera is the router?
Many thanks for your patience.
My camera Yi home 720P black color Global Europe version and using this camera for several years without problems and after last updates to yi home app camera started to not connect giving -90 limited error! After this Kami company came everything broken sadly! Today I removed my camera from the app also resetted the camera put out sdcard! And tryed to pair again! First QR code scanned successfully then Connected to Wifi successfully then after some minutes camera goes back to yellow light pairing waiting to connect mode! Im computer engineer also do not even try to say classic pairing help to me because this camera already working 7/24 for several years! So the problem is the Kami company broken the app also maybe broken the connectivity or blocked old cameras to not connect maybe they force people to buy new cameras! But how! if I get this problems why I will buy camera from them again! I tryed 5 times reset the camera poweroff camera re-install app remove all the old data files! Tryed again pairing but always after connect to wifi successfull sound! camera going back to yellow light waiting to connect mode again! Since my camera Europe version I selected Germany as country! Im waiting some " Real Solution"
Hey @eltdesign Can you update your firmware for this camera model? What firmware is this currently running? I recommend contacting our support team at www.kamihome.com/contact for any firmware related requests.
I can update of course but where is new firmware? My camera serial number 22eutwlbqg bought around 2017-2018 and firmware also was 2017 I guess. Since now I cant access to camera cant write exact firmware version but inside the yi app there was no any new firmware update available! This camera worked several years without problem but after last 1-2 month started to give problema first 6 second free video cloud stopped working then camera cant access giving -90 limited error always stuck on %5 loading.
Also The main problem after company change You started to use location based connection rules! And app is checking the location is correct or not! If not correct not let the people pair the camera! This ia the biggest problem now. I bought this camera from china and its globai europe version and my country is Turkey! Before on yi app we can select just Europe and it was enough now there is no europe selection and if I select Turkey app giving error (not accept Turkey as europe very strange also) If I select another europe country since app checking the location from phone and directly block camera to pair! there is very high amount of users using this camera’s and everybody now having problems!
Im waiting urgent help about this connection blocking problem! Cant use my camera now! Cant even pair! Your servers is blocking our camera to pair!
What a company! Killed my 3+ years working Yi 720p home camera and not giving any possible support! and saying 720p project on hold! Come on! We payed money for this camera!!! You cant force people to buy new camera! Blocking people to pair! Im still waiting urgent solution I dont have security on my house because of you!
Hi @eltdesign Have you contacted our support team? This needs to be escaleted internally so we can better resolve the issue. I do apologize for my delay. But, I will make this a priority.
Please contact support by going to www.kamihome.com/contact. Send me your ticket number I will escalate the ticket.
We will get this resolved.
Is evident Yi are modified the firmware to break old cameras, these in Europe is reportable to the competent autority, is not normal Shop one product and modify it via firmware to break… Not mor Yi in my home and I’m not going to recommend it to anyone at all.
