I am trying to setup the Yi 1080p camera. But when it connected to power, the orange light is on.
I try to add the camera, I do not hear anything from the camera. It is not saying “Waiting to connect”
I tried reset. after pressing the button, there is nothing happening. the camera still show a steady orange led.
Hey @hq83 Thanks for coming to the community forum for more information. I am sorry to hear you’re having issues pairing your camera.
Can you power cycle the camera? Unplug, plug in.
And, try again?
Has it ever connected to the app or is it a new addition?
Hi @Steven_Kami, this camera has been bought quite long ago. more then 6mths ago. but it was not used. was kept in sealed box till now.
Just opened it yesterday and try to set it up. It was not connected to the app before.
The app is also newly created. Just download and create my account yesterday.
Yes, I have tried to power cycle a few times.
Pressing reset button also nothing happen.
Support case has also been logged. 606588
Hey @hq83 Thanks for the info. I am going to follow your ticket and make sure we get this resolved one way or another.
Do you have an SD card installed? If so then remove the card and see if it will allow you to set it up. If that works then the SD card may be bad or it may need to be reformatted
just an update. issue has been solved.
Case was logged from the app.
after investigation, photos and videos provided, support conclude that issue is with camera and was told to check back with my seller to get a replacement/refund.
Requested for the firmware to update the camera using SD card. was told that this would void the warranty.
Contacted my seller and was redirected to email supportasia@yitechnology.com.
This support went through the troubleshooting steps and provided the firmware file.
Updated the camera firmware using SD card. and the camera is working now.
Case close.
Not sure what the different between both of this support, and why can’t the firmware be provided with the first support.
Thanks for updating the forum. Let me do some digging on that one but it strange you got different feedback.
i have the same issue, can i get the firmware too?
Same problem. Camera worked for months, suddenly disconnected. All other cameras still worked.
I attempted to re-connect the camera.
Power down, reset, etc, even reset router and had the camera right next to the router for setup.
I get to the part where it tries to read the QR code, and nothing happens.
I know the QR function works, I can read these codes elsewhere. I went to the QR code reader in the account/help section of the phone app, and the QR code reads fine.
I have 9 cameras, the Yi 1080p, and the others function.
I took one of the working cameras down to the location of the malfunctioning camera to verify that the signal is OK. That one would not connect, either. When I put the previously functioning camera back to its original location, it would no longer connect and I get the same error when trying to re-connect.
I recently purchased 2 new outdoor cameras, and they both have the same problem, the QR code will not read. In addition, the language on the 2 new cameras is not English.
I removed the SD card to test and still no connection.
I have sent several emails, but each response is the same, the tech does not read previous emails and tell me to do the same steps, ALL of which I have done repeatedly.
I supplied all the information asked for. They want to replace all 4 units. Is this the only option?
If I cannot rely on these cameras working reliably in the future, it may be best to scrap all 9 and get another brand.
ticket number: # 1127090
same thing is going on with one of my cameras, can I
get the new firmware also
me ha pasado lo mismo, y no consigo conectar nada se ha puesto ha hablar en chino. necesito el firmware para europa pero los enlaces estan rotos y no los consigo. donde puedo encontrarlos
donde puedo encontrar el firmware para Europa de la YI1080p Home Camera, Model: YYS.2016.
As per my knowledge, If the reset does not work and the orange light remains on, there may be a firmware issue. Try disconnecting it for a few minutes before plugging it back in. If it does not work looking for available firmware upgrades or contacting customer service may be the next best approach.
I hope this will help you!
Respected community member!
son unos estafadores, les mande un tiket por el mismo problema y me dan un monton de excusas para no mandarme el firmware, cuando la camara se me estropeo por una actualizacion de ellos!!
I have been talking to support and telling them about firmware and still keep telling me they can not update firmware with so card. I see you got it done. I have 5 cameras and for about 5 years this is first time with problem and customer service is terrible. When I reset it will not sat waiting to connect and I have tried everything they tell me. They keep having me do the same things over and over.
ho anche io lo stesso problema , acquistate a settembre 2024
facendo il reset la spia rimane accesa gialla e non si sente nessun suono
potreste aiutarmi
grazie
ho anche io lo stesso problema, acquista a settembre 2024
potresti aiutarmi
grazie
IO HO LO STESSO PROBLEMA, HO RIACCESO E FATTO RESET MA NON SUCCEDE NULLA, LA LUCE è SEMPRE GIALLA FISSA. SONO FOTOCAMERE NUOVE MAI COLLEGATE ALLA APP
POTRESTI AIUTARMI
It seems that this is a common problem. I have 3 YI cameras. This YI Dome U Camera Pro stopped working. It stopped responding to the app.
It will not reset with the provided pin. The yellow light is constantly on. I have unplugged it many times and tried the reset many times. I have tried other USB cables and removed the memory card.
I believe this may have happened during an automatic update. Is there anything I can do to restore the functionality?
Hello
I ve go the same problem two cameras went offline one with orange and three times blue the other one blue solid but unable tro connect…
I tried to reset cameras but on the solid blue on nothing no reset and even if i plug off and on exactly the same…the other reset ok but after some hours went offline again with blue 3 times and orange solid…
The only way to make them work again is simple…I changed the ac adaptor…and now all is ok…
So Try to use another power usb adapter
