Yi 4k+ action cam does not turn on
Hi there.
I have a Yi 4k+ action cam (Model YAS.1817). It worked for about 2 years, but I didn’t use it a lot, so it’s like a new condition. Recently I tried to record some video footage in 4k, but the camera turned off and failed to turn on. After that, it somehow turned on a couple of times and showed the message: «trying to restore», then turned off again. And now it doesn’t turn on at all. I can’t turn it on nor from the battery, nor from the direct USB-C cable connection. There’s no light indicator, no sound.
  • I had the latest firmware installed 1.4.14
  • I have two new additional batteries, and it doesn’t turn on with them too.
  • I’ve tried multiple USB-C cables and it doesn’t work too.
What I’ve noticed is when I inject the battery it makes low volume constant clicky noise, like a bootloop?.
For me, it looks like a low-level firmware issue, and the camera is totally bricked. I heard it’s possible to reset camera with ELF files.
What can I do guys?
Hello you would be best to contact Customer services and see if there is anything they can help you with
https://kamihome.com/contact/
Hey, thanks. I’ve created a ticket for Kami support too.
P. S.
Here’s the clicky sound the camera makes when the battery is inserted
yi4kplus_battery_noise.m4a
If I insert a type-c charge cable, clicky sound changes to a short beep, and then it becomes silent. See this sample:
yi4kplus_incamera_charging_beep.m4a
Hey @Hyperc0der That sounds frustrating. I am sorry to hear you’ve had challenges. Did you include these clips in your message to our support team?
Can you send me the ticket number assigned by our team?
@Steven_Kami Current ticket number is 550226. https://help.yitechnology.com/hc/en-us/requests/550226
The first ticket I created by chatbot (549972) missed my issue description so I closed it.
