Hi there!
I have a QZT 1080p fhd and it can’t connect to the wifi anymore. I’ve tried everything specified in the forum: no 5Ghz, triplechecked password, reset, location allowed in Android, etc. Is there anything else I can do?
I tried the firmware upgrade using sd card, but I didn’t know which file to use…since here you always talk about YI models.
I also opened a case with support: #533996.
In case it helps, logs:
03-21 16:31:15.910 rmm.c:1688|zbar_proc() decoded QR-Code symbol “b=EUSqtbxG9XangUoy&s=UHVjZWxh&p=S1wkMjIOBkwnMAwbGgFQXVZSIQ==”
03-21 16:31:15.911 rmm.c:1229|trans_info() trans_json info=b=EUSqtbxG9XangUoy&s=UHVjZWxh&p=S1wkMjIOBkwnMAwbGgFQXVZSIQ==;key=&p=
03-21 16:31:15.911 rmm.c:1301|trans_info() trans_json result=S1wkMjIOBkwnMAwbGgFQXVZSIQ==
03-21 16:31:15.912 rmm.c:1229|trans_info() trans_json info=b=EUSqtbxG9XangUoy&s=UHVjZWxh&p=S1wkMjIOBkwnMAwbGgFQXVZSIQ==;key=&s=
03-21 16:31:15.912 rmm.c:1301|trans_info() trans_json result=UHVjZWxh
03-21 16:31:15.912 rmm.c:1229|trans_info() trans_json info=b=EUSqtbxG9XangUoy&s=UHVjZWxh&p=S1wkMjIOBkwnMAwbGgFQXVZSIQ==;key=b=
03-21 16:31:15.914 rmm.c:1301|trans_info() trans_json result=EUSqtbxG9XangUoy
03-21 16:31:15.914 rmm.c:1710|zbar_proc() rmm got /tmp/got_wpa ssid(Pucela) pwd(sentaditoensutejado) bind(EUSqtbxG9XangUoy)
03-21 16:31:15.926 dispatch.c:3619|do_mq_process() dispatch got (0x70)
03-21 16:31:15.927 dispatch.c:707|choose_server() in choose_server, region_id = 16, api_server = https://plt-api-de.xiaoyi.com, sname = neutral-r10, dlproto = mieu
03-21 16:31:15.927 rmm.c:1217|send_wifi_conf_msg() msg snd success
03-21 16:31:15.974 dispatch.c:3667|do_mq_process() got pwd(sentaditoensutejado)
03-21 16:31:15.974 dispatch.c:157|send_connectting_msg() msg snd success
03-21 16:31:15.974 dispatch.c:5316|do_mq_process() Process (0x70) end
03-21 16:31:15.974 dispatch.c:3619|do_mq_process() dispatch got (0x1004)
03-21 16:31:15.974 dispatch.c:5312|do_mq_process() invalid msg 0x1004
03-21 16:31:15.974 dispatch.c:5316|do_mq_process() Process (0x1004) end
03-21 16:31:16.932 dispatch.c:1852|do_monitor_wifi() ioctl(536899594) error(1),Operation not permitted
03-21 16:31:16.933 dispatch.c:1854|do_monitor_wifi() wifi disconnected, now reconnect wifi
03-21 16:31:20.120 dispatch.c:3565|p_worker() rcd may crashed
03-21 16:31:25.270 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:31:25.270 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:31:27.006 rmm.c:1377|msg_proc() got RMM_SPEAK_CONNECTTING
03-21 16:31:35.271 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:31:35.271 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:31:45.272 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:31:45.272 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:31:55.273 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:31:55.273 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:32:05.275 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:32:05.275 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:32:15.276 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:32:15.276 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:32:22.017 dispatch.c:3565|p_worker() rcd may crashed
03-21 16:32:25.277 watch_process.c:171|check_watch_info() cloud crashed!
03-21 16:32:25.277 watch_process.c:171|check_watch_info() p2p_tnp crashed!
03-21 16:32:26.306 dispatch.c:1817|do_monitor_wifi() timeout reset wifi
03-21 16:32:26.306 dispatch.c:1820|do_monitor_wifi() wifi connect timeout
03-21 16:32:26.307 dispatch.c:1824|do_monitor_wifi() ioctl(536899596) error(1),Operation not permitted
03-21 16:32:26.308 dispatch.c:3619|do_mq_process() dispatch got (0x1003)
03-21 16:32:26.308 dispatch.c:5312|do_mq_process() invalid msg 0x1003
03-21 16:32:26.308 dispatch.c:5316|do_mq_process() Process (0x1003) end
03-21 16:32:26.314 dispatch.c:183|send_pwdwrong_msg() msg snd success
03-21 16:32:27.655 dispatch.c:3619|do_mq_process() dispatch got (0x1002)
03-21 16:32:27.655 dispatch.c:5312|do_mq_process() invalid msg 0x1002
03-21 16:32:27.655 dispatch.c:5316|do_mq_process() Process (0x1002) end
03-21 16:32:27.655 rmm.c:1150|send_wait_msg() msg snd success
Cheers!
