I have a weird situation. My camera has the solid yellow light. I have tried all the suggestions on the forums and ones I can find on the web. When the camera is plugged into a power supply the light stays yellow but if I plug it into my laptop it works perfectly. I’ve tried using different power supplies, different lengths of cable, with the memory card, without the memory card, setting it up plugged into the laptop then switching to a mains power supply. Literally everything I can think of. Has anyone had this happen and if so how have you solved it?
James
