I have a Yi Home camera in a reasonably small location. When the night vision comes on, it is so “bright” that it turns itself back off. Is there a way to “dim” the night vision so that it doesn’t turn itself off. The light is very bright which is seemingly great, but since it is in a small space it reflects and seems to overpower the camera which then shuts the night vision back off. It will do this over and over again and will turn on for about 1 second and then turn off for about 10-15 seconds and then on for 1 second and then off for 15 seconds. If I could somehow turn down the light or make another adjustment it would be great.
Hello I don’t believe it is possible to reduce the intensity of the light created by the infrared lights. Could the location of the camera be slightly amended to reduce the effect of the glow?
Could you introduce some secondary lifting or alternative IR so you could turn off the IR lights altogether?
I have seen examples where the IR glowing off a wall or another surface can cause what you are suffering.
If these don’t work it might be another camera brand you need to try - but these too could suffer the same behaviour.
Hey @petman2 I agree with Yorkshire. Have you put the camera in other places to try and see if that resolves the problem?
@YorkshireUser Thanks for the help fun tips!
You’re help throughout the community is awesome!
The problem goes away if I move it, but then the camera is useless. I guess I can try to blackout some of the lights with a sharpie or something that would then obscure some of the light. Thanks for the suggestions, I will let you know if I figure something out.
My camera is located inside the house, inside a window, pointed outside. The infrared lights cause a very bright glare, however. When I turn them off, I can see enough outside to do with street lights, but immediately, the LED lights come on and stay on which causes a lot MORE glare. Today we finally covered all of the lights, LED and infrared, with duct tape as we are better off without any of them. It would be nice if there was a way to turn them off.
You can change your settings just to daylight only that stop’s the inferred lights coming on
shireking
There is no way to do it. I tried putting tape over it and still couldn’t get an acceptable result.
There is a way to do it just turn the lights to daylight only
shireking
How do you suggest it see in the dark with daylight only? You missed the point.
Get an outdoor camera with inferred indoor ones will just reflect inferred from glass
Just put the indoor one outside. They last a couple years even when they are outside. I have one in the middle of the garden year round, completely unprotected from rain. Put a little tape on the SD card opening and you are good. For $20, I find it better to just replace them every year or two then deal with an outdoor one.
Had an indoor camera outside for years under cover away from direct rain best if using camera indoors looking through windows is to set it for daylight only
shireking
