I have an Yi home camera since 2 years. Model Number YYS.2016. Since 1 week the camera seems off line. No image etc. I’ve tried a power off / power on nothing. So I try to reconnect to the wifi and after the reset, the won’t speak. I’ve no sound only the yellow led. I’ve tried the procedure to reconnect it, the led turn to blue, stop blinking but after 1 mn the device says that the pairing is failed. I’ve open a ticket and the solution is to update the firmware but due the camera won’t connect I cannot update the firmware.
I hope that the camera is not brick but I would like to try a manually firmware update with the sd card so I cannot find the firmware.
Could you help me ?
