I have tow of these camera there suppose to connect to Google home assist.
I live in Ontario Canada when I run through the
Promos to add YI home camera it says completed but does not take me to the camera section so I can add them to the rooms I tried using Kami as well since they’re both on the same website and I was an accessible as well I need some help not sure what to do or where to go.
wojo71
Could you try the YI IOT app
And see what happens?
I am trying to use the international version Yi app or Kami app it says downloads successful but the app does not load to the Google home web page for the setup and it should automatically go to my camera screen and it doesn’t bring them up.
Hmmmmm.
I thought the Yi Home and kami home were only for use with Yi or Kami branded cameras. I assume you can see the camera pictured in the app?
For google home these are the required steps:
In order to set up your YI Home cameras to work with Google Assistant, please follow the directions below:
Set up YI Home devices to work with Google Assistant
How to view YI Home cameras on Google Home Hub
Step 1: Create a YI user account and set up a camera
- If you haven’t already, please download YI Home app from Google Play and create an account
- Follow the instruction to set up camera(s)
Step 2: Connect YI Home devices to Google Assistant
- Open the Google Home app
- Tap the + symbol at the top left, to Add a device
- Under “Add to home” select the Blue Plus symbol to “Set up device”
- In the Set-Up page, select “Have something already set up?” at the bottom
- In the “Manage accounts” page, find “Yi Home Camera” from the list
- In the next step, enter your YI Home user account email and password and authorize Google to access your devices
- Select cameras from the list and add to a room
Step 3: Control the YI Home cameras from Google Home Hub
- You can give voice commands such as “Okay Google, show me the living room camera”.
- To stop viewing the camera, you can say “Okay Google, stop”
When I connect my Google home instead of my Alexa, @YorkshireUser
Some helpful tips from my good pal YorkShireUser. How did it all turn out @wojo71
