unplugged camera alert-YI indoor camera
/How do I know if a camera was unplugged and then plugged back in? I tried it using the cloud, but couldn’t find in the timeline where the camera was noted as offline and a time stamp made of when it came back online. Thanks for any help!
Hello @HiyaCC thanks for joining the forum. I don’t think it is possible to know if a camera was unplugged and plugged back in sometime in the past. You could have to catch someone in the act (for example if you saw your camera connect drop out and went to investigate).
If you have an SD card in it, and set to Continuous recording you will see the blank section on the timeline as long as it was within the timeframe of the period the SD card is due to save…ie last 24 to 48 hours
True. Good point Brian.
