Scheduled Automatic Deletion of Added Memory Card?
Is there a way to schedule each camera to delete the footage on a specific date? I use the 64gb memory card and it usually fills up after two weeks. Is there a way I can have it automatically delete all footage instead of having to manually do it? Thanks!
Hello. You shouldn’t need to delete footage manually when it fills to capacity. The software and card should loop record.
Is there a lock on the card - not sure if that’s old now but there used to be an overwrite slide lock on cards years ago.
I would consider formatting the card from within the app and monitor that.
Hey @tyler0312 Def take a look at the advice and feedback from @YorkshireUser above. He know’s his stuff!
