Hi when you select motion detection schedule do you the need to arm the camera or will it arm when the time is reached many thanks
Hello @markrich, welcome to the community!
Are you referring to the alert scheduling? or Power on/off schedule?
For the alert schedule, the camera will only send you an alert notification within the time schedule you set for the camera. For the power schedule, you can set the time when you want the camera to power on or power off.
Alert schedule for example ive edited the time do I then select arm and when it’s disarmed will it auto arm at the next selected times
You just need to choose Start and End time. The camera will send you alerts within the start and end time. The app will stop sending alerts once the schedule ended and will only start sending alerts once the schedule is reached again.
Thanks for your help
