Hi there! Great news - There is a new firmware update for the Kami Wire-Free Outdoor Camera! So if you haven’t already, please make sure to update your firmware so that your Kami is in tip-top shape and ready for action!
Before we get into the following steps on how to update your firmware, let’s make sure you’ve done everything necessary to get your camera ready!
To make the best and correct use of the product, we’d like to strongly encourage you after receiving your camera to first fully charge the batteries before inserting them into the camera to pair it.
You will also need to make sure that you are using the latest Kami Home or YI Home App on iOS or Android. You’ll be able to update your camera’s firmware directly from your App whenever a new firmware update gets released. We highly recommend that you keep your camera’s firmware up-to-date.
Once you’ve guaranteed you’ve done the previous two items, all that’s needed is pairing! After you’ve paired your camera (Here is a video on how to pair your Wire-Free Outdoor Camera) you can then update your firmware to the latest version!
Need help updating your firmware? No worries! Follow these 4 simple steps to get your Kami Wire-Free Outdoor Camera updated in no time! With the latest Kami Home or YI Home app, the firmware update should be prompted automatically once you tap the Kami Wire-Free Outdoor camera in your Home app.
In your Kami Home or YI Home app, you will tap your Kami Wire-Free Outdoor Camera feed on the Home screen.
When you see the notification for a new firmware update, click “OK”.
Next, you will see the current and the latest versions of the firmware. Click “Upgrade”.
You will then see the message, “The firmware upgrade is starting and normally requires 4 to 5 minutes (depends on internet connection). Please keep your device connected to the network and powered on.” Click “Confirm”.
That’s it! You’re all set! Hopefully, you found this helpful! Have a great rest of your day!
