Kami Home or YI Home application for PC no longer works
hello I have just changed to buy a DELL XPS15 9520 and there is windows 11 Pro
I can no longer run my PC applications on it
while it worked very well on the previous one bought 6 months ago DELL XPS19 9510 with windows Pro
I can not enlarge the images of the cameras
it freezes
the bit rates are blocked in reception when I put 9 cameras
YIHomePCClientIntl_Setup_1.0.0.0_202010211000
KamiHomePCClientIntl_Setup_1.0.0.0_202003271500
PC 12th Gen Intel® Core™ i9-12900HK 2.50 GHz
I have no problem running or YIHomePCClientIntl or Kami on W11Pro. I don’t remember what name the Kami app had. I uninstalled it because of similarity and I didn’t need two. The YiHome app has more current DLLs when I examined them. You might try the other whether YiHome or Kami.
Thank you for the reply. I uninstalled and reinstalled each of the apps several times. And I always have the same problem whatever the application.
My PC is new and it has never worked while I have the same one with a different processor but the same version of Windows 11 and everything works properly
I think the problem comes either from the compatibility with the processor or with the graphics card
give me the links of the most recent applications available for europe please
https://kamihome.com/firmware/
thank you for these 2 links
I will test like this
without forcing them on the NVIDIA card
and I’ll see if it works out
thanks in advance
the Kami version made a Force Close in less than 2 hours
I am testing the YIHome version.
Here is Force Close on Kami home PC after 2 hours
I blocked the 2 applications on NVIDIA to see
but it’s not better
on Intel I have no stream after a few minutes
That link is now 404. And Kami even refers to it in their FAQ. Poor show.
I used the software for more than 2 years without problems. Then i Got RTX5070 and problems began.
Now it causes extreme pc freezes. I deinstalled it and now i get the same error post.
YI, Kami, whatever IS THIS? The link is down and noone fixes it. Come on, please do it!
Try the download here. I scanned with antivirus and malwarebytes with zero issues, and I used the scan QR login on my mobile app, which logged me in, and everything is now peach. I use a Gigabyte 5090. Granted, the feed is a little grainy, but it works again. I was about to cancel my sub if this wasn’t going to work anymore. I hate the mobile app and prefer the PC version. yihomepcclientintl_setup_1.0.0.0_202010211000
