๐ก๐ฒ๐ฒ๐ฑ ๐๐ผ ๐ฅ๐ฒ๐๐ฒ๐ ๐๐ผ๐๐ฟ ๐๐ฎ๐บ๐ฒ๐ฟ๐ฎ ๐ฎ๐ป๐ฑ ๐ฐ๐ผ๐ป๐ป๐ฒ๐ฐ๐ ๐๐ผ ๐๐ผ๐๐ฟ ๐ฌ๐ ๐๐ผ๐บ๐ฒ ๐ฐ๐ฎ๐บ๐ฒ๐ฟ๐ฎ๐?
๐๐ณ๐ฆ ๐บ๐ฐ๐ถ ๐ณ๐ฆ๐ค๐ฆ๐ฏ๐ต๐ญ๐บ ๐ค๐ฉ๐ข๐ฏ๐จ๐ช๐ฏ๐จ ๐บ๐ฐ๐ถ๐ณ ๐๐ช-๐๐ช ๐ค๐ฐ๐ฏ๐ฏ๐ฆ๐ค๐ต๐ช๐ฐ๐ฏ?
๐๐ช๐ฅ ๐บ๐ฐ๐ถ ๐ถ๐ฏ๐ฑ๐ญ๐ถ๐จ ๐ต๐ฉ๐ฆ ๐ค๐ข๐ฎ๐ฆ๐ณ๐ข ๐ฃ๐บ ๐ฎ๐ช๐ด๐ต๐ข๐ฌ๐ฆ ๐ข๐ฏ๐ฅ ๐ฏ๐ฐ๐ธ ๐ต๐ฉ๐ฆ ๐ค๐ข๐ฎ๐ฆ๐ณ๐ข ๐ช๐ด ๐ฐ๐ง๐ง๐ญ๐ช๐ฏ๐ฆ?
๐๐ณ๐ฆ ๐บ๐ฐ๐ถ ๐ค๐ณ๐ฆ๐ข๐ต๐ช๐ฏ๐จ ๐ข ๐ฏ๐ฆ๐ธ ๐ถ๐ด๐ฆ๐ณ๐ฏ๐ข๐ฎ๐ฆ ๐ข๐ฏ๐ฅ ๐ญ๐ฐ๐จ๐ช๐ฏ?
Well, donโt panic, you can try to reset your camera and re-connect using your new wifi password/ account.
Use a thin needle or pin to reset the camera.
The reset button is located on the upper left side of the QR code on the backside of the camera or you may need to remove the back cover of your camera (depending on your device version).
Please hold down on the reset button until the yellow light turns on. The reset is successful when the yellow light is on or you hear the voice โReset is successfulโ.
Watch the video tutorial on ๐๐จ๐ฐ ๐ญ๐จ ๐๐๐ฌ๐๐ญ ๐ฒ๐จ๐ฎ๐ซ ๐๐๐ฆ๐๐ซ๐: https://youtu.be/5DnkhLiZICc
๐๐บ๐ฝ๐ผ๐ฟ๐๐ฎ๐ป๐ ๐ป๐ผ๐๐ฒ ๐๐ผ ๐๐ฒ๐ ๐๐ฝ ๐๐ต๐ฒ ๐ช๐ถ-๐๐ถ ๐ป๐ฒ๐๐๐ผ๐ฟ๐ธ.
1.Bandwith
Depending on your network bandwidth and latency, you can choose different picture quality and bitrate (Standard/HD/Auto) to keep the camera connected.
2.Router configuration
- YI home camera currently supports only 2.4Ghz band, it does not support 5Ghz band Wi-Fi
- Ensure that the Wi-Fi name is in English letters and numbers and the password does not include special signs.
- Ensure that the router encryption mode is WPA/WPA2
- Open the QOS in Advanced settings, set the device at the highest setting
- Turn off the wireless access control on the black and white list and cancel the option of black and white list
- Turn off the AP isolation in the setting of the router
Watch the video tutorial on ๐๐ก๐๐ญ ๐๐จ ๐๐จ ๐๐ ๐๐๐
๐ ๐ฉ๐๐ฌ๐ฌ๐ฐ๐จ๐ซ๐ ๐๐ซ๐ซ๐จ๐ซ? here: https://youtu.be/96V2eI_tGAc
Watch the video tutorial on ๐๐ซ๐๐๐ญ๐ข๐ง๐ ๐ญ๐ก๐ ๐๐ ๐๐จ๐ฆ๐ ๐๐๐๐จ๐ฎ๐ง๐ญ: https://youtu.be/jEoY7KLq4Ns
If you like this message, please donโt forget to click โLIKEโ
and drop your comment below.
Thank you and have a great day!
DinaFromYI
