Setup a few times with both yi apps yihome and pro and it logs in to the amazon skill and even finds the camera but when i ask the Echo Show 8 to show “xxxcam” it goes away and teh screen flickers as though it is trying to load the rtsp data stream 5 times then comes back with “The camera is not responding”.
Tried to enable the Kamis kill as well to see if that is the issue as the pc app when you click on hte links takes you to kami website not yihome but still nogo!
Have removed the camera from the skill and re-added but it still will not connect.
Is this because the camera is already setup for the PC Yi Home Camera application as it does not seem to want to play ball with Alexa?
