Camera does not want to reset
Hello
I have 2 YI camera that I am having issue to reset
1080 p indoor
1080p Dome indoor
Both are blinking in blue and orange. when I press the reset button nothing is happening. I do not hear < Reset successful > at any time. I have tried to put the firmware on the SD card but it does not change anything. Did that already happen to one of you ? any tips or idea ?
THanks
Hello @pilsner08, sorry to hear about the issue with the camera.
Have you tried doing the software update through the YI Home application?
I cannot as I cannot discover the device to add it into the application
The devices are blinking in blue and orange but I cannot put them in mode reset or waiting to connect
Please try restarting the Wi-Fi router or use a different network. Also, try to use a different set of cables and adapter also try out a different outlet.
I ordered the same camera off of Amazon and I had the same issue I had to return it and I’m waiting so I can get my refunds so I can order another one I was so excited about getting it plugged in and loved the resolution but then couldn’t reset it so I had to return it
I figured out the solution remove the SD card and then try to reset again the SD card
Remove the SD card and try to reset again it should work that time
Remove the SD card and try to reset again the SD card is what’s making it not work
